Advice needed about problematic new hybrid mountain bike.
4 Nov 2011
N.I
Evening,
My wife bought me a new hybrid mountain bike at the start of june. I had been using an older bike prior to that and found it quite hard going so my wife bought me a Carrera Subway 1 Mens Hybrid Bike from halfords (£300)
http://www.halfords.com/cycling/bike...ns-hybrid-bike
From the moment I started using it, it felt like a much better bike but after a few minutes use I noticed the chain crunching and popping everytime i put any pressure on the pedals ..ie cycling up a small hill etc, this was on the 2nd gear on left and 8th gear on right. So I moved to 7th gear and proceeded. The problem remained and after a couple more runs on the bike, the 7th gear started doing the same thing...crunching and popping etc, so I shifted to the 3rd gear on left and noticed the problem would occur less but still would happen. I cycle 20k a day on the same route...a dual carraige way with a slight incline, so no off road etc. I found the 7th and 8th gears were ideal for the route i take and with no sign of the problem dissapearing I took it back to halfords where they informed me the bike hadn't been set up correctly. So i left it with them and collected it 2 days later. The problem reoccured almost immediately and although slightly better, within days was back to being unusable in either 8th or 7th gear. The following weekend I took it back down and they, again, set it up. This has went on since june with every 2 weeks or so me taking it back down for yet more setup work. Each time the bike has been unusable after a week or two. In total it has been back to them 5 times and shows no sign of improvement.
As I am a bit clueless with bikes I wanted to know, is this something I should just accept and live with or should I ask for a replacement etc? I have never experienced this kind of recurring problem with any of my previous bikes and the route I take is hardly demanding on the bike. I am at the stage where it is affecting my daily journey and I kind of feel I shouldnt have to accept this.
Is this a common issue thats easily resolved or should I be asking halfords to fix/replace/refund etc as 7th and 8th gears are unusable?
thanks for reading
It will just need setting up. Start by making sure your chain is clean and lubed and then watch this - https://www.youtube.com/watch?v=Bbk5RcH0bbQ
It is a key skill to have but TBH once you get it right it should be OK for some time. Perhaps there was a lot of cable stretch over your first months of ownership or maybe the Halfords crew did a bit of a numpty job on it each time.
Thanks for the reply, I will check out that link. What concerns me is the reoccuring nature of the problem combined with 6 setups from halfords in total. The problem is as bad as ever so maybe let them have another go or take it to somewhere competent.
Hmm, if they've had it back to set up the gears (I'd expect even Halfords mechanics to be able to set up gears - aren't they all Cytech trained?) and it's still skipping it could have a gear bent gear hanger - when worked as a cycle mechanic I'd say one in ten bikes we got in had damaged gear hangers resulting from shipping and we'd have to correct them.
I'd take it to a reputable local bike shop and let them have a look.
