Hi
I'm looking for some advice on cooling requirements for the pc I'm planning to put together soon. I want to air cool rather than water cool.
Main heat generating components are as below:
Case: Fractal Design 7
CPU: AMD Ryzen 9 9950X3D
GPU: Nvidia 5070 Ti
1x Samsung 9100 Pro Pci-e 5
1x Samsung 990 Pro Pci-e 4
I've done a little reading about CPU coolers and the Noctua NH-D15 G2 seems to be recommended even if it is a little more expensive.
The Fractal Design case has 2 front 140 mm fans and 1 rear 140 mm fan. Would those fans along with the CPU cooler fans be sufficient to keep everything sufficiently cool? Or will I need to add more case fans?
GPU: Nvidia 5070 Ti
