Hi All
After a few suggestions for things that might have caused my pc to die.
Spec in Sig, overclock is orthos stable (has used at this oc for 3 weeks now) and the RAM is fine (checked again with memtest last night). I have just checked the hard drive with the WD diagnostic program thingy and thats fine too.
Problem is that I can't get into windows, even safe mode doesn't work, It almost booted but then I think I got a quick flash of BSOD, was to quick to catch what it said. I'm sure I could just re install windows (though I have not tried yet) however if I do that it could just die again.
Any suggestions on things that may have caused this? I have tried reverting to stock clock and ram speeds and this makes no difference.
Many thanks.
Dave
Many thanks.
Dave
