My son's PC is dying. The MoBo is suffering from leaking capacitors so takes upteem attempts to get it to start.
I could replace the capacitors or just the MoBo but to be honest it could do with a refresh.
Don't want to spend a huge amount and it doesn't have to be a super system.
This is what I am thinking of buying
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+)
Gigabyte 970A-DS3 AMD 970A (Socket AM3+) DDR3 Motherboard
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
And I need 4GB RAM. Was going to go for 2x2GB Dual channel DDR3 but not sure which to get.
I have a AMD system myself and remember being a bit disenchanted with what was advertised and what you could actually get running on AMD in reality.
I don't want to overclock, just run at the speed that the RAM is advertised at.
But from past experience, AMD just picks up the JEDEC and can't pick up the XMP, so getting to run at the advertised speed can be fiddly and unsuccessful.
Is this still the case?
The AMD FX-4 and AM3+ motherboards say support upto 1866. But is I were to get something like this
http://www.overclockers.co.uk/showproduct.php?prodid=MY-137-CR&groupid=701&catid=8&subcat=1517
Advertised at 1600MHz @ 8-8-8-24
am I going to find it difficult to run at anyhting othet than
1333MHz @ 9-9-9-24
Basically, I don't want to mess with paramenters, or overclock, I just want to be able to select the speed.
Is there a recommended RAM for AMD - remember that I don't want to spend a lot.
Cheers,
Nigel
1333MHz @ 9-9-9-24
Cheers,
Nigel
