- 23 Feb 2009
Hi and Happy New Year!
I have a slight dilemma with my next PC and require your advice please. I need to update my self built Pentium 4 3.2ghz system office PC which was built a few years ago and has reached the end of its service! Even though it is still working, I hate using it as my other PC’s are of a higher spec and much nicer to use. Its main use is office applications, Internet, email also a bit of video and audio editing.
So, I decided to replace that system by ordering a Dell Vostro Core i5 system (costing £470) even though I have had a bad experience in the past with Dell. Prior to purchase I was told that I would receive my new PC within 7-10 days. However, when I checked the order status a few days later to my surprise estimated delivery date shown was mid February I cancelled the order straight away!
I’ve been looking around in the high street stores for a PC that I could buy there and then but failed to find anything that I liked in terms of look and spec. I did a self build last year which was a Core i7 system which was built for my studio (Audio/Video editing, Audio production etc). So I am now thinking to do another self build. I could use the old case and hard drive from my P4 system which means I am looking at £350-£400 for the upgrade components (Right??)
Questions are:
1. I am better off with a self build or off the shelf?
2. Is the Core i5 system too high spec for the use? (I am thinking futureproof as I intend to keep this for some time. I found that I still do the odd intensive task on the office PC despite have a specific PC built for that.)
3. Or do I just work with the P4 system by overclocking it, install Windows 7 on it and carry out all intensive work on the i7 system? (try not to recommend this one hahahaha!)
Thanks for your help on this..
Questions are:
