Advice needed on monitor for photo editing
18 Oct 2002
Ireland
Which of the following monitors do you recommend for photo editing. I will not be doing any gaming. I have a colormunki so calibration is no problem.
Hazro HZ30WiG V2.0 10-Bit 30" LED Widescreen Professional Monitor £659
http://www.overclockers.co.uk/showpr...=17&catid=2898
Only one input. No onscreen menu. Small company slow to respond to emails
OR
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black £479
http://www.overclockers.co.uk/showproduct.php?prodid=MO-099-BQ&tool=3
This monitor gets really good reviews. Colour rendition is very good. The real selling point for me is the shape of this monitor and the display resolution which allows the following 2560 x 1440 resolution provided a comfortable pixel pitch and font size we felt which might well be preferred by a lot of users compared with the small fonts on 27" models carrying the same resolution.
The problem for me is it's an AMVA panel and not IPS. Does it matter that much?
OR
Dell UltraSharp U2715H 27" Widescreen LED Monitor - Midnight Grey
http://www.overclockers.co.uk/showproduct.php?prodid=MO-080-DE&groupid=17&catid=1120
My exixsting monitor is a Dell 2407. and I have been happy with it
My preferences are as follows
1st BenQ
2nd Dell
3rd Hazro
What I really need to know is what GPU should I get that will be suitable for any of the above monitors so that I can view at full resolution. I'm currently using an ASUS P8Z68 mobo with an i5 Sandybridge oc'd to 4.5GHz. My graphics card is a lowly ASUS 6670 1024 GDDR5 PCI-Express card
Thanks
Euge
