I've just bought a white Phanteks Enthoo Primo case to kickstart a new desktop build, and have spent the weekend staring inside it wondering where to put things. This is my first watercooled build (not counting closed loop cheaty stuff), so any advice is welcome.
I haven't got an exact spec yet, but it will probably be a 4790K devil's canyon and dual 780s in a Z97 board.
I'm aiming for a mostly white build - hoping they haven't become too cliched yet - and to that end have put together the following partial shopping list.
YOUR BASKET
1 x XSPC AX480 Quad Fan Radiator - White £109.94
1 x EK Water Blocks EK-D5 Vario X-TOP - Plexi (incl. pump) £89.99
1 x XSPC AX240 Dual Fan Radiator - White £74.95
1 x EK Water Blocks EK-Supremacy Clean CSQ £49.99
1 x Bitspower Z-Multi 150mm Water Tank £36.98
2 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - White £29.99 (£59.98)
3 x Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) £25.00 (£75.00)
2 x Monsoon 19/13mm (OD 3/4) Rotary 90° - White £9.95 (£19.90)
2 x Monsoon 19/13mm (OD 3/4) Rotary 45° - White £9.49 (£18.98)
2 x Primochill Primoflex Advanced Tubing 19/13 - Clear £5.99 (£11.98)
Total : £557.28 (includes shipping : £8.00).
My plan for the case layout is something like this:
The pump sits in the back compartment of the case on the mounting bracket next to the PSU. Flow goes reservoir -> pump -> bottom 240 rad -> GPUs -> top 480 rad -> CPU -> back to reservoir.
In no particular order, my questions are:
1) The fan/radiator setup is currently designed for ease of fitting. Both rads are push, with the top quad rad pushing air into the case and the bottom dual rad pushing air out. The case also has two 140mm fans on the front and one 140mm fan on the back (which I may remove). Does this airflow make sense or should I be doing something else?
2) I've chosen 19/13 tubing, which will presumably reduce resistance and increase flow. Thinking about it, it seems quite thick. Is this tubing easy to handle?
3) I've picked up the idea that the Corsair SP120s are the best fans for radiators. Am I right? I want this case to be as quiet as possible, are the low noise ones any good?
4) Any other glaringly obvious noob mistakes?
TIA for any help.
YOUR BASKET
TIA for any help.
