Advice needed on power of PSU???
1 Jan 2007
Hi,
I am currently in the process of putting a kit list together to build my first PC & I am in need of some advice on what PSU I will need to power the following components: -
1 x Asus P5N32-E SLI NF680i SLI, S 775, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX Motherboard
1 x Intel Core 2 Quadro Extreme Edition QX6700 CPU
1 x EVGA GeForce 8800 GTX KO ACS3 SILENT 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail Graphics card
1 x OCZ 2GB (2 x 1GB) PC2-9200 1150 MHz Watercooled Dual Channel DDR2
memory
Will I need a 1000 watt psu or will I get away with a samller unit?
Thanks.
Thanks for the advice Will but OcUK recommends a minimum of 550 watts for the 8800GTX graphics card alone.
I am now really confused because another guy on a different forum also recommended a 480 watt PSU would do the trick.
IAmATeaf said:
The Corsair 620 would be my minimum TBH, have a look also at the Enermax range.
The HX620W will power that easily- the 520W would probably do it fine but I'd go for the 620W anyway. On another note, buy yourself a sensible processor- there's no point wasting money on QX6700- I would have thought an E6600 would be more than fine ;)
Hi
I have my entire rig running on a 600W tagan with no strain or instability what so ever, in fact I have had it running on a 480w tagan easily and even a budget 350w from an old computer case ran the rig although it wasnt happy when under load.
To be honest with you as long as you get a decent, named and stable powersupply, some from tagan, corsair etc you will be fine, personally id go for a tagan dual engine 600w or above or a corsair 620.
Mike
That system would run off 500W but I would advise going with something like the Antec 650W, Corsair 620W if you want head-room for overclocking CPU, memory GPU etc.
I'm running a Tagan 580w and have been for 5 months with my BFG 8800GTX
no problems.
C2Duo6700,Abit IN9 32X, BFG 8800GTX.2X1GB CORSAIR 8500, 2XWD RAPTOR 150GB, TAGAN 580 W
