Advice needed on power supply
24 Apr 2019
Hi,
Im putting a new build together. I have a b450 msi pro carbon motherboard, gtx 1060 and planning to use a ryzen cpu, nothing too extravigant. Im not planning any crazy oberclocks.
However i was planning to use my existing 600w PSU, which isnt anything fancy and about a year old.
Will this be sufficient to use? My concern was causing damage to any componants if it is not up to spec. I have used it on my last build i5 3500 without issue. I just dont want to fry anything
I will be changing it at somepoint when i can afford.
The PSU is Antec VP600P, the link:
https://antec.com/product/power/vp600p.php
Thankyou, what started out as a motherboard cpu upgrade has got more costly, i will replace it at somepoint but didnt want to risk it harming the new board in the meantime.
Planning on a six core, by the looks of it the new ryzen chips use less power
