Hi Guys
thanks for the replies, its a single loop water cooled system, i put 2 x Rad's in cause i could really, no other reason, thought it would look cool, i had a Thermaltake CL-W0132 P500 Pump 500L/h pump in there but it refused to push the water round the system at anything other than a trickle hence my question.
those intrested in the case, "My Opinion" fairly well made, thin Alloy (bit flimsy) all over except the front which is about 6mm thick, medium sort of weight but ******* heavy once you have filled it up with stuff, i cart the thing to a LAN every week and i must say its a little tiring. loads of room for water cooling which is why i bought it but be aware you CANT fit full lengh Graphics cards in it, its very short, its not as well built as a Coolermaster or Lian Li but not far short, biggest plus points, loads of room & Excellent cable tiding areas, 2 down falls, no room for full lengh G-card & expantion card quick release bracket are crap
