Okay, so I'm in the process of deciding parts for my new build. I'm going from an Antec 900 to a white Corsair 600T (already bought and arrived!). I have a 5870 which I'm going to keep for now, and just recently got a OCZ ZX 850W Modular PSU. Will also keep my DVD drive from current build, and my 750GB HDD (7200RPM).
This means I am looking to get a new CPU, CPU Cooler, Mobo and RAM. I think I've decided on my set-up and would appreciate opinions!
Mobo: Sabertooth P67
http://www.overclockers.co.uk/showproduct.php?prodid=MB-449-AS&groupid=701&catid=5&subcat=1906
£153
CPU: i5 2500K
http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN&groupid=701&catid=6&subcat=1275
£176 (on sale atm for £168)
RAM: Corsair Vengeance Arctic White 8GB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-311-CS&groupid=701&catid=8&subcat=1517
£60
CPU Cooler: Corsair Hydro H60
http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=57&subcat=1395
£63
Total: £452 (or £444 if i get it now which I prob won't, or the OEM version)
Would this be considered a decent build? I'm trying to go for a black and white simplistic look (along with good components obviously!), I even got some white pre-braided cables for when I build it!
Also - this is my first ever build. My other PC was pre-built.
Problem comes however when installing windows, I would do a fresh install onto my hard drive, but I only have an upgrade disk. But I still have my Windows Vista disk, so I guess I could install that and then upgrade to windows 7? To make things worse though, I'm building my dad a PC out of my old parts and his, but he has XP and I won't be able to activate my Vista (and then 7) key on 2 machines right? It's all very confusing! Not sure if I should just buy Full Windows 7. But it's so expensive! (Just read on my Vista disk + windows 7 upgrade disk that its OEM software. Does this mean I won't be able to use it again with a new motherboard? I hate all this!)
Also, I'm not sure whether I should try save that bit longer for an SSD to boot windows up on. Would I have windows and installed programs on there, then all data such as games, music and movies on my 750GB HDD? Is this easy to set up - and will 120GB be enough? I cannot afford the 250 GB versions.
Sorry for the many questions and long post, but advice is much appreciated
Thanks in advance!
£153
CPU: i5 2500K
£60
£63
Also - this is my first ever build. My other PC was pre-built.Problem comes however when installing windows, I would do a fresh install onto my hard drive, but I only have an upgrade disk. But I still have my Windows Vista disk, so I guess I could install that and then upgrade to windows 7? To make things worse though, I'm building my dad a PC out of my old parts and his, but he has XP and I won't be able to activate my Vista (and then 7) key on 2 machines right? It's all very confusing! Not sure if I should just buy Full Windows 7. But it's so expensive! (Just read on my Vista disk + windows 7 upgrade disk that its OEM software. Does this mean I won't be able to use it again with a new motherboard? I hate all this!)
Thanks in advance!
