Hi guys
Just a after a bit of advice on replacing my gfx card. My OcUK 8800GTX has given up the ghost and having had it since dec '07 it is now out of warranty.
I need to find a half decent replacement which would hopefully perform just as well - but - I'm kind of limited to £100 max on spend.
CPU is a stock running E6750 (4gb mem) and these days I tend to only mess about on WoW, although I do run it on my LCD TV at 19020 x 1080 resolution with everything on high.
I've been very happy with nVidia in the past and was considering the XFX GTS 250 (although it seems out of stock atm). Not sure how the 250 compares against the 8800.
I'm not sure if there is anything better for the same money that ATi can offer up as I've kind of lost track with the pc hardware scene since taking on the responsibility of becoming a single father (hence the £100 limit!).
Anyway, appreciate any advice you guys can offer up.
Thanks in advance
a1ias
Thanks in advance
a1ias
) and though I haven't played it in a while, the time may come when I fancy going through Crysis again.
Honest you won't regret the bit extra ££
