- 17 Jan 2006
Hi all I'm new to the forum, was trying to find advice on graphics cards, stumbled across this forum and thought you guys might be able to help me.
Basically I am going to upgrade my graphics card from the Geforce FX5200 that came with the computer and has up until now been a fine card, even playing Halflife 2 without a problem (ok not at massive resolutions but perfectly acceptably!!!)
The rest of the system is as follows:
Processor is a 2.8ghz Pentium 4
1 Stick of DDR-Ram - 512MB
Network card built into motherboard.
Soundblaster Live 5.1 sound card
Pinnacle systems Studio DC10+ video capture card
1 DVD drive
1 DVD-RW drive
2 Hard Drives - IDE
The power supply is a 300W power supply from someone called Powerman or soemthing like that, (it came with the computer).
My mother board does not have a PCI express slot so I'm limited to an AGP card and I'd prefer an Nvidia one ideally. I'm not looking necessarily for a top of the range mega expensive card, but I do want something which is a significant step up from what I have and that will be able to run Halflife 2 and Farcry well.
I want a card which has both DVI and VGA outputs as I want a dual monitor setup.
I was contemplating one of the 6800 GS cards (http://www.overclockers.co.uk/acatalog/6800_Series.html) would one of these be suitable??? Or are there better options available (baring in mind that I won’t be over clocking cos I really don’t know enough about the technical side of computers to feel comfortable about doing so)
From the reading I’ve been doing I believe I will need to upgrade my power supply in order to be able to use this card (or indeed pretty much any card of similar performance), now this is an area I really know nothing about. Having looked at a few places and not really know what I’m look for (other than the fact that it needs to be greater than 300W…)
Can anyone recommend any PSUs?. I don’t really want to be spending huge amounts on this but I want something that will let everything run fine.
Phew, sorry for the long first post but I wanted to include as much as I could to make it easier for anyone to give me advice.
Thanks in advance for any help anyone can give me.
Valve
1 DVD drive
1 DVD-RW drive
2 Hard Drives - IDE
Valve
