I'm deciding if I should upgrade my current spec:
P4 3.0ghz
1GB
x800GT
I know this is very out of date and I do need a upgrade. I don't have a big budget(£500) but I do have a monitor, hard drive and DVD drive. I will mostly be using this for gaming but at the minute im not playing anything that is a graphics powerhouse.
I've come to two setups;
I will buy a graphics card a bit later (around Christmas) with this setup and use my x800GT
or
This has a decent graphics card which I'll probably have to upgrade anyway.
I wont be over clocking from the start but will probably do some later.
So what would you pick?
P4 3.0ghz
1GB
x800GT
or
