Advice needed
Permabanned
10 Nov 2010
Disneyland
I'm thinking of getting the following components to upgrade my system. I already have a case, hard drive, dvd burner and a psu.
Could i do better for my money than the parts i have chosen? Any help would be appreciated. Cheers in advance.
That monitor looks a good bargain at that price and i will definitely consider getting one. I need a decent cooler as i am going to overclock to around 4.5Ghz. The cooler i have chosen seems to be ok for the price.
What if I told you that Anandtech got to a easy 4.4GHZ with the stock cooler - http://www.anandtech.com/show/4083/...-core-i7-2600k-i5-2500k-core-i3-2100-tested/3
So get a bigger heatsink later on if you want to go higher.
So you can get that 24" screen and still be bang on £600
