advice needed
27 Feb 2014
Hi all,
I need some advice on a new pc build, in the past i've always had laptops but have decided that since my last laptop was basically a desktop replacement it lost its ability to be a "laptop" as it was too big and heavy to be portable. I figured if i'm going to have always be at my desk makes more sense to get a desktop.
I mainly need this for work, I'm a software developer so will require software like (lamp stack, java, phpStorm, maybe netbeans etc no graphical software) will plan to have both windows and linux installed as OS's.
I would also like to be able to play games on this machine, currently i have a 23" wide screen monitor resolution 1920x1080 (i do plan on getting a second monitor in the future) but for the basis of this chances are i will only ever play games on singal monitor of 1920x1080 as im not a massive gamer.
Games i would like to play would be GTA, COD, modern warefare etc (all latest versions) but would also like to be able to play future games even if the settings were between low-medium.
The current research i've done suggest a i5-5670 & a GTX770 would suit my requirements and could probably get away with a 600w power supply? but as for other requirements CPU cooler, motherboard etc im not sure about.
my budget is around 900 - 1100 ideally around the 1000 mark (i dont need monitor, keyboard, mouse, speakers etc) if some kind soul could help me out with a build i would be very grateful.
I think i would prefer intel & nvida over amd however my mind is not closed on non-intel i have just always had intel.
Thanks guys sorry it was a long message i just wanted to give as much info as possible to be helpful :)
Are you looking for a pre-built PC or would you be putting the components together yourself?
Hi Fulax,
I'd love to build it myself, but im all thumbs and no fingers lol so think for peace of mind in not breaking something pre-built would be the best option.
Here's a custom spec for your consideration:
YOUR BASKET
1 x Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) £329.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £167.99
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Corsair Carbide 300R Mid Tower Case - Black (CC-9011014-WW) £65.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
1 x Asus 24x DVD±RW DRW-24F1ST SATA ReWriter - Black (Retail) £19.99
Total : £1,060.31 (includes shipping : £17.85).
And a pre-built system for the same money:
YOUR BASKET
1 x "Titan Tanto" Intel Core i5 4670K @ 4.2GHz Overclocked Nvidia GeForce Gaming PC £313.00
- 1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLYD38G2133HC11ADC01) £67.99
- 1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £161.99
- 1 x NZXT Phantom 530 Full Tower Gaming Case - Red £104.99
- 1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
- 1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
- 1 x Standard Build Systems - Dispatched within 7 working days £0.00
- 1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
- 1 x No Second Hard Drive Option (ZERO Cost) £0.00
- 1 x Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) £275.99
- 1 x No Sound Card Upgrade £0.00
Total : £1,056.44 (includes shipping : £11.25).
Needless to say, the self-build option is the better system by a decent margin. The 290 is a much better card than the 770, and you get an SSD in there. SSDs are awesome. The motherboard is also better, and the RAM is a bit faster.
So if you're willing to give it a go, you'll certainly be getting more for your money if you put the parts together yourself. It seems daunting at first (I built my first PC - the one in my signature - back in November), but it is surprisingly easy to do. And fun. My usual advice is to look up Newegg's How to Build a Computer series on Youtube. That will give you an idea of the building process, and whether you want to try it yourself.
