Currently running the Corsair 500d RGB se case with the Asus ROG ryuo AIO cooler and a front mounted 240mm radiator. The setup uses the usual 3 Corsair RGB fans on the front then the radiator then the 2 120mm fans that came with the AIO - pull- pull method - tested other ways of doing it and this gave the best result ( top 2 and rear fans all exhausting )
To add to this I have ended up with some EK water blocks kit, including 1 x 240mm radiator and also 1 x 360mm radiator - this kit will be used to the GPU ( RTX 2080 that's causing big heat issues in the case )
So the question is where to run these radiators,the triple or double EK in the front after the corsair case fans, then a set of ( EK Vardar ) fans then my aio radiator then another set of fans ( the aio ones )
the case does have the front end depth to allow for this.
that's three sets of fans pulling in through two radiators :/
other options are to run the AIO in the roof ( only one set of fans can be used to the clearance )
The run the GPU 240 or 360 setup using a pull pull setup in the front of the case.
does any of that make sense ?
/me waits for the hate of running an AIO for the CPU and an overkill GPU cooler
TIA
TIA
