- 24 Dec 2007
So I was holding off to see how the 9xxx series ended performance wise but after seeing the prices I'm even more convinced that I want to go AMD. I intend to potentially replace the 2700x with the new AMD CPUs in future depending on how much better they end up being.
A few things/questions:
1. I will be using my current 980ti until either the 2080ti's reduce in price or I can see how the AMD cards perform next year so I don't need that with the build.
2. I will be buying a 1440p 144Hz monitor to combine with that once I know whether I'm going Freesync or Gsync
3. I don't intend to overclock as from what I can tell Ryzen doesn't overclock that well and it basically handles that on it's own, is that correct?
4. I'm open to suggestions for replacing components, these are just to give an idea for the overall build - memory specifically I've only stuck with the same kit for comparison. Also I have no idea on power supplies so I'm completely open to changing that if anyone knows better than I do.
5. I want a motherboard that has really good onboard audio and is good at overclocking if I do end up doing that in future. Otherwise I don't know enough about motherboards at all to make any comparisons.
6. Is 3200Mhz memory acceptable or is it better to choose the seperate components and change that to faster speeds? What is a 2700x best paired with?
I'm looking for advice on what combination to go with if anyone can help.
First option:
My basket at Overclockers UK:
And the second option:
Is the Asus board worth paying an extra £100 and losing an extra SSD? I could potentially even drop the 1TB drive down to 250GB or something due to the extra SSD depending on how good that SSD is or even sell it seperately for £50 or something and increase the price difference.
Thanks!
First option:
- 1 x Seasonic Focus Plus 850W 80 Plus Gold Modular Power Supply= £124.99
- 1 x Samsung 970 EVO Polaris 1TB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive= £269.99
- 1 x be quiet! Dark Rock Pro 4 CPU Cooler= £68.99
- 1 x Fractal Design Meshify C Midi Tower Case - Black Tempered Glass Window= £89.99
- 1 x AMD Bundle - AMD Ryzen 7 2700X, Asus Strix X370-F, Team Group RAM *FREE 480GB SSD* *ONLINE ONLY* = £608.96
- Memory Capacity:Team Group Dark T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey (TDGED4
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £299.99
- 1 x Asus ROG Crosshair VII Hero (Wi-Fi) AMD X470 (Socket AM4) DDR4 ATX Motherboard= £259.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey (TLGD= £149.99
Thanks!
