Advice on a 350 to 450 build desktop
17 Apr 2020
Looking for a new desktop system between £350-£450 my current build is below but died earlier today ,out of the loop on current builds but looking for something a bit better than i have and something i can upgrade in the future, Need it to be able to run the new xcom chimera squad and warhammer total war 2 and phoenix point. I would most likely upgrade later so entry level is fine as long as it can cope with my games.
I've looked at a lot of parts the problem i have is with Covid 19 buying all the parts from different people means i will be delayed so if there are any all in one builds in the UK id definitely prefer that.
CPU AMD FX-6300 RAM 12.0GB Dual-Channel DDR3 @ 799MHz (11-11-11-28) MotherboardGigabyte Technology Co. Ltd. 970A-DS3 (CPU 1) Graphics 2048MB ATI AMD Radeon HD 7800 Series (ATI AIB) Storage 298GB ssd
You'll need to fault find. If rest of system was find and was CPU/mobo then ..
My basket at Overclockers UK:
Total: £369.47 (includes shipping: £10.50)
If it's just GPU then gtx 1660/RX580 would be handy .
Might be PSU ? Paper clip test ?
AMD planning to release Ryzen 3300X soon, would have been wonderful for this budget at £100 hopefully
You could have a look at 2nd hand parts as getting a decent CPU my ram and Gpu on that budget is quite tough, maybe consider the 1600AF over the 3600.
Would definetly check the psu though first.
