I am thinking that this would be a good build, I was not too sure about the memory if it goes well with the motherboard.... I read a lot of posts and it seems that this motherboard does have problems with some memory. Any advice on this system build would be appreciated.
Processor- Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB)
Motherboard - Gigabyte GA_P35_DS3P rev2 (Socket 775) PCI-Express DDR2
Graphics card- Sapphire ATI Radeon HD2600 PRO 512MB DDR2 HDTV/Dual
DVI (PCI-Express)
DVD Drive - Asus DRW-1814 BLT 18x18 DVD+RW Serial ATA Dual layer
Memory - Geil 2GB PC2-6400C4 800HMZ ultra low latency DDR2 dual channel
mainly for light multi media work and some gaming.
Thanks in advance for your input
DVI (PCI-Express)
