- 15 Apr 2017
Intel Core i5-7500 3.4GHz Quad-Core Processor
£173.94
CPU Cooler??
Asus PRIME Z270-K ATX LGA1151 Motherboard
£120.95
Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory
£61.92
EVGA GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card
£129.95
NZXT S340 (Black/Blue) ATX Mid Tower Case
£64.17
Power Supply
Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply
£59.99
Target is a reasonable spec to run games at nearly full res with decent fps. Dont really want to spend more than that but wonder if some is overspec (motherboard?).
After advice if thats a good system spec for the cost?
What is a good CPU cooler?
I have SSD and HDD that I will use from the previous one.
Is that power supply OK as seems a very good cost. Is it enough power, possible in the future might want to run 2 vid cards at once (if thats possible)
Edit removed the links oops!
£173.94
CPU Cooler??
£120.95
£61.92
£129.95
£64.17
Power Supply
£59.99
