I currently have an E6600 but im buying an E2160 because i need a cheapish second computer.
im also wanting to replace a couple of parts in my current spec so i need a bit of advice on what motherboard and ram i should get.
the parts i want to replace in my rig is;
OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
Fatal1ty abit FP-IN9 SLI
now the reason im asking is because i wish to overclock (prefereably my E6600) but at the moment all i can get out of it stable is about 2700mhz. i think personally its the motherboard thats limiting me but im not that clued up on these things.
the first spec is a proposed spec for the lesser machine(not to be used by me
) i have included the parts i want out of my machine in this spec.
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
x-1950-xt
Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU
and for myself;
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB)
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTS OC2 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU
the only thing i have missed out of my proposed spec is memory because im not sure what to get, so could some please advise me on some memory. and also do you think i would be better off putting the E2160 in my machine to overclock?
oh and i know theres no HDD's etc but i have those.
) i have included the parts i want out of my machine in this spec.Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
x-1950-xt
and for myself;
