Advice on a non-gaming monitor
17 Oct 2005
Southampton
We've got an 'office'-type PC. It's got an awful 10-15+ yr old LCD panel attached to it.
My wife has started using this computer more to do graphic design, a bit of photoshop, image editing for crafting, that kind of thing.
Any recommendations for a screen, about 27", excellent image quality, which will absolutely not ever be used for gaming (so 144/300Hz screens are not required!). Not bothered if it's a shiny or matte finish on the panel. Ideally, it won't cost the earth...
Does such an item exist?
I've bought a few Dell S2721DS displays recently which are pretty decent for the money.
I'm running two of them alongside my older, but much more expensive, Dell U2715H and there's no obvious difference (once calibrated).
Dell (in particular the Ultrasharp range) would always be my recommendation for design/image editing. Just from looking at specs, the U2719D seems to be an outstanding choice, but it also depends on your definition of "won't cost the earth"
My 4K monitor scales to 150% at 3840x2160 by default. I can run 2560x1440 at 100% scaling but it’s better at the higher resolution despite of the scaling.
Is an office type pc going to be able to drive a 4K monitor? It's worth checking.
I did look into this, a valid comment! Apparently the onboard graphics max out at 2560x1600, so would require the additional purchase of a cheap dedicated graphics card, I guess a GeForce 1030 or similar would be fine?
"Cheap" and "graphics card" are two things rarely seen together in the same sentence!
I would not get 4K. It's just too fine for a 27" monitor in my opinion and the higher the screen resolution the slower various applications will be, certain photo edits are painfully slow on a 4K screen. Just my humble opinion of course, I would get a 2560x1440.
Photo edits at 4k (or any resolution) aren't really "done" by the GPU, it's a CPU intensive task for the most part. If it's an old PC with a fairly dated CPU then you should probably go for lower resolution but a better quality monitor, so yeah something along the lines of the Ultrasharp. Doesn't sounds like what you are after is too taxing so a good quality 27" 1440p with good colour accuracy would sound like the sweet spot in my opinion.
OP wants something halfway decent at a reasonable cost to replace a what they describe as an 'awful 10-15+ yr old LCD panel'. By post #13 people are suggesting spending Eizo type money! WTF!
Dell's current Cyber Week deals are decent savings on their monitor range.
I'm eyeing up an U2719D to complement my Benq GW2765.
What’s the verdict on scaling? Would a 1440p monitor being run at native resolution look better/worse than a 4K monitor upscaling from 2560x1600?
Don't run a monitor at a resolution lower than native. Use Windows' scaling.
I have a 27" 4K monitor (150% scaling), a 24" 4K monitor (175% scaling), and a 34" 3440x1440 monitor. Text is noticably nicer on the two 4k monitors with smoother curves but I'd be hard-pushed to differentiate between the two of them.
