Hi,
I have been looking at getting a switch for a little while, so I can have my PC/TV/PS3/Laptop wired at the same time without needing to change around the wire in the wall and now I need another one too for my parents business so wanted some advice on a sensibly priced one that would do the job.
The one in my room will be used like I said above, connected to a wall jack in my room then I will connect my PC, TV, PS3 and Laptop to it, would be nice to have a spare port too maybe.
And the one at the business would be connected to a wire from the router (upstairs) and that switch will have a DVR and a credit card machine connected to it.
Please can you suggest a switch for both of those situations as I'm not really sure what to look for when buying a switch, as in do I need a managed or unmanaged one? What's the difference?
Don't want to spend too much, but don't want it to be slow either
Thanks,
EDIT: A switch is the component I need right?
Thanks,
