Guys, looking to help a friend upgrade his system. He's hit me with a budget a little lower than I expected. He's looking for a new motherboard/cpu/gpu/ssd combo for under £300, ideally under £250.
depends what he wants oc offer some options
i3 - 4160 £100
SSD - 120gb £39
A cheap z97 motherboard (they start at £62)
Leaves around £90 for a gpu if he's willing to spend £100 - Gigabyte Geforce 750ti is £90
It's nothing crazy but thats what you get for that budget..
If it's for gaming. With ram this is slightly over budget but it should play pretty much anything. A cheaper ssd could also be used instead although I, not a fan of the lower end Kingston ones that were cheaper
