Hello all. I have an older computer:
Asus A8N sli deluxe
Athlon 64 Fx 55 cpu 2.61 Ghz
Sli Asus gtx 7800's
2 gig ram
Win xp pro
Now I have tried to overclock as much as I can but it hasn't made a whole lot of difference. I went for advice from my local comp store and was told that I was rather limited in what I could do. I was told to get rid of the sli cards and go for a single 9800 card. I could also step up to an FX 60 dual core but then that would also create issues with some older programs I am running. So I would probably have to stick with the FX55. Can somebody (and you seem to be the people to ask), suggest what I can upgrade to to get the most out of this aging system?
Hope you can help
Regards to all
Asus A8N sli deluxe
Sli Asus gtx 7800's
2 gig ram
Win xp pro
Hope you can help
Regards to all
Is it more expensive than gold yet?
