Advice on Athlon XP-M, please?
i found quite a nice boost, and ig loved it :)
edit: sempy with dual channel (c and q on)
you'd have to show me some benchamrks then, because running dual channel @ 240mhz fsb on my nf7-s, there's very little difference between that and single channel in anything except sandra memory benchmark tests.
And from experiance, socket a loves memory speed, not nessesarily memory bandwidth.
im sorry i dont have any of my own - skt a is gone :(
it deffinately helped ig though, im shure i could find benchies for that on the net
All i remember is that for gaming it was virtually <5% across the board. The cpu's themselfs had an upper ceiling of 3.2gb/sec from the northbridge anyway, which coincidently is the bandwidth of a singel stick of ddr400 (otherwise known as pc3200;))
the only beinifts dual channel really brought were in the efficiancy stakes. the best i ever got out of mine was about 95%. in other words, at 200mhz fsb with a thoretical max of 3.2gb (and that's in single channel mode) id get around 3gb/sec in sandra. That was as good as it got, which isnt great when dual channel @ 200mhz has a theoretical max of 6.4gb/sec:) but again, that's down to limits of the cpu, not the memory or motherboard.
That was @ 241mhz, dual channel.
I know that trying to see if there was any difference in performance from Single or Dual on the NF7S, I found at best about 5% improvements and even thats a bit exaggerated.
The thing is, that if you are wringing the PCs neck to get that extra bit out of it, then that extra 3-4% can make all the difference.
as i say, it made ig a lot faster :) - pi time went up a bit with dual channel aswell, gave a decent boost
problem with full implementaion on 939 is the single cores hardly use 3.2gb let alone 6.4gb (i am aware of the pc rating being the bandwidth ;)) the duals dont need the 6.4 either, i understand the move to ddr2 however, as quad cores a comin and that will need more bandwidth
