- 3 Nov 2010
cheers is the ram that was linked earlier still the best choice with the MSI carbon pro B450 board i ordered.
The Mugen - should be suffice and is fantastic value - performance and noise on a par with Noctua. The Fuma will accommodate low profile memory (only) - and width/length will make accessibility to components/connections difficult as a result.cheers again. I have looked at the scyth fans and there seems to be 2 similar ones. Not sure which would suit me more
there is the mugen rev b or the fuma rev b - both seem AMD4 compatible. the fuma seems to have 2 fans
the fuma looks wider so would that hinder my build.
No, 16Gb is ample for your needs. And yes the LPX memory is fine.i also assume that i dont need 32GB at this stage. I am only interested in gaming and watching movies
A larger conventional drive as you will eat through that 480Gb very quickly - unless keeping a very restricted/contained system?i dont think i am missing anything else?
Sensible - especially if not clocking.and decide on an air cooler or see if the stock wraith cooler is good enough.
These will hits 2933MHz (like all other 3000 kits) - but there's a chance you may hit higher or force tighter timings at lower frequency:just need to get some ram
Get the 3333MHz set if the same price - both run tighter timings at 2933MHz (15 17 17).HyperX Predator HX432C16PB3K2/16 DDR4 16 GB Kit (2 x 8 GB) 3200 MHz DDR4 CL16 DIMM,
ARE THESE WORTH AN EXTRA £9 - THEY ARE 3200 £89
also they have 3333 speed Hyperx predator at the same price
Depends - if you got it running at 3200MHz (or close) - i would argue yes, especially when you look at the price of guaranteed 3200MHz sticks at £160. Plus, you would be able to run tighter timings if you had to drop to 2933MHz (3000MHz).so its worth an extra £9 for 3333 ram over 3000 speed. Excuse my ignorance but this is all new
Do you mean just the case fans?I think i followed everything but the fan installation seems confusing to me. My case will be the HZTX H500 which comes with 2 fans. can someone confirm where they should be plugged into the MB
X470 Gaming Pro - no.Is the x470 msi gaming pro better than the b450 carbon pro
