Advice on BD-R media please
16 Oct 2008
I'm guessing in the next 2 months i will move over to a Blu Ray burner and need some advice on the media to use.
The most important thing to me is the reliablity of the media, i don't want to go back to it in 3 years to find it's all gone, so my questions are what kind of media should i be looking for 25GB/50B discs or even this new 100GB BDR XL i'm guessing not the later given it's new and very little feedback on quality, also on the disc issue what are the best manf in relation to both 25GB and the 50GB media to use?
I have no idea on the drive yet that i will look at once i have worked out media side of things.
All1
I will be honest you would be better on other forums for this kind of help mate . Im way out of bd-r stuff now but at the time Panasonic was the stuff to go for then falcon then verbatim .
Then you have the whole LTH vs HTL debacle (htl being the better off top of my head) . I would genuinely search for other mediums of arching and storage to be honest
Hi marcus_667 thanks for the honest reply.
I did a wee bit of googleing last night and came up with some intresting reading on reddit so i will huint of some more specialist forums :D
All1
