- 8 Feb 2004
- In the wetlands...
Hi all,
I have an old PC, I used to keep up-to-date with things but then I had a child and free time and money went missing...
So, my current spec is:
Essentially, given the age of this, I am now of a mind to change the case (BitFenix Shinobi cases get some unpleasant stickiness on the 'soft touch' part), and downgrade it to a PC for my son to use for school work (oh, and maybe Minecraft...)
My issue is that I'd like any new PC to probably come in at around £1000 , is there either a strong candidate for something that would be a decent starting point and step-up from the above that can then aim to improve smaller parts of (RAM, etc) to ensure it'll still run games on reasonable settings? It's not like I play much cutting edge stuff (this build lasted me through Witcher 3, which was probably the last 'new' game I played), but it's good to have something that can handle more strenuous things (for example, I tried to play Kingdom Come: Deliverance on the above, and it was horrendous and even struggled on low settings).
Thanks
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
- Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard
- Corsair Builder Series CX 600W V2 '80 Plus' Certified Power Supply (CMPSU-600CXV2)
- BitFenix Shinobi Gaming Case - Black
- Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
- Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366)
- MSI GTX 980 Ti Twin Frozr 6G 6 GB Gaming Graphics Card
- HDD is a combination of HDD/SSD, system was originally built when SSDs were expensive so I used to run a smaller SSD with OS and all games on a 1TB HDD; but now have a 500GB SSD and the 1TB HDD... I don't think this is much on an issue though.
Thanks
