- 13 Oct 2007
Hi all can i get some advice on a build that i am going to place.
The main useage will be gaming with some basic photoshop work.
I have added the option of a pre configured watercooled case.
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor
1 x Asus Maximus IV Gene-Z Intel Z68 (Socket 1155) DDR3 Motherboard
1 x Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9)
1 x Sapphire ATI Radeon HD 6950 FLEX 2048MB GDDR5 PCI-Express Graphics Card
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive
3 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003)
1 x LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (OEM)
1 x Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-650TXV2UK)
5 x Akasa SATA-III 100cm Rounded Data Cable
1 x OcUK V8 Watercooled Case - Cooler Master CM-690 Lite Dominator **2011 Compatible**
Also need to look for a monitor aswell so any advice would be helpfully 24" and above
Regards
Nick
Regards
Nick
