Hi,
Im thinking of building a budget gaming PC (never done this before) max budget would be £500, and parts would be bought each month, and also i would need a complete system - tower, windows etc
Due to my limited budget, i would buy the components each month, however im not sure where to start ?
I did think maybe get the processor first (have £150 to start this) - i had a look at overclockers web shop and see they have the AMD piledriver fx 6300 for £79.99
Is that a good choice or is it worth trying to get an intel processor - overclockers have intel core i5 - 3570k for £159.99, double the price of the AMD FX 6300. is the intel worth the extra £80 ?
Then i have no idea which motherboard to get - any suggestions ?
I would appreciate any advice.
Thank you.
Thank you.
