I've been fighting with my system for past few months and finally I think its kicked the bucket.
Of course there are other options like replacing the PSU if thats the culprit but I would like the option of replacing as I need this system working.
I was browsing OCuk's shop and working out what would be suitable.
Are there any newer CPUs out (the i's i3-i7) that wouldn't be an improvment on my Q6700 (Which I was running at 3.33ghz), i'm guessing theres more to a cpu than just clock speed?
With regards to cash, I can't spend too much because I don't even have the money yet but I don't want to spend over £500.
I need this system for gaming and most importantly work/study which is music production related (Home studio kinda stuff), so CPU Power and ram may be important.
Most if not all the parts from my current PC can be reused except the RAM I believe as its ddr2. But I have 3 internal SATA drives, a GTX460 and a 8800gts (was using for physx).
To summerise.
Is a bundle the way to go? or building a system on the site but leaving out components.. Or buying all parts seperately and getting it built by a shop or self?
I'd appreiciate your expert advice on where to go and what I may have forgotten to consider!
David
To summerise.
- A decent enough upgrade from a Q6700
- Motherboard needs to have e-sata at least 1 port and 7.1 onboard sound
- Already have harddrives, graphics, monitor, keyboard/mouse etc
- Budget under £500 preferably around £400
- Potentially a motherboard cpu ram bundle unless theres other alternatives on the OCUK shop or elseware.
David
