- 18 Oct 2008
- UK
hi,
im in the middle of a build in which im getting a coolermaster HAF and already bought the thermalright true 120 black heatsink.
i have removed from the old case > 6 case fans of which i had
3x xigmatek xlf-f1253 (black/orange fins/white light) (120mm ... 1500rpm... 61cfm ... under 20dba)
and
3x a.c.rynan blackfire 4 (blue uv frame/orange uv fins/ uv light) (120mm ...2000rpm ... 29dba ... 77cfm)
what i need to know which to use on the heatsink and which on the HAF side panel, bearing in mind the case insides will be using uv lights.
i only ask as some say the true is best with 1500 and some say 2000+ but then that gets noiser and im not sure if 4x1500 is comparable cfm wise to the 230mm fan on the HAF side door.
cheers.
HRhino
and
cheers.
HRhino
