I'm checking components for a new build and am trying to sort out a case.
The MB will be Intel Socket 775.
I've checked reviews on all the main components and am now beginning to suffer from a bit of information overload.
Having refined my thoughts on the case the main criteria are:
1....A top class case - I'm quite happy to pay a premium for a good case ie Lian Li or similar.
2....Good sized Midi or Full Tower although I'd rather keep the size down a bit and I certainly won't fill a Full Tower.
3....Reasonably 'quiet' - I may change/add quiet fans to suit - probably Noctua.
4....Good air circulation and filtering on the intakes.
5....I may well get a MB with heatpipes so as I understand an inverted MB layout will not suit.
6....Removable MB Tray - this will be my first build.
7....Preferably a reasonably conservative appearance - nothing too flash.
8....The location of the PC means if there is a door it ideally should be hinged on the left.
9....PSU at the top to minimise potential problems with the leads reaching the MB although I'll take advice on this if need be.
10..Able to take a single 8800 Graphics Card without being a tight squeeze.
11..Possibly a case with space behind the MB to route the cables and improve airflow.
12..Space for a CPU heatsink - probably the Noctua NHU-12F.
13..A re-set button - some cases don't seem to have one which I find surprising - perhaps it’s just me.
I appreciate I may have to compromise but any advice will be appreciated.
Thread Closed.
Good luck in choosing your new case (An Akasa Eclipse is for life)
