Advice on code organisation
1 May 2006
Bristol, UK
Evening all,
I've decided to give my personal website a thorough overhaul over the next few weeks. I originally created it in January and being my first hand coded site its sloppy and the code is badly organised.
I've recently got to grips with Photoshop so at least I can make the site LOOK a bit better :p
However, I want to re-organise my code because at the moment I have a separate file for each php action :eek: I'm thinking of creating something along the lines of a 'master' php script which uses various includes (EG: Input > Process > Output) that way I can keep all of my includes stuffed out of the way.
Could anyone enlighten me with how they organise their code to make everything more manageable.
Edit: Although I've never used them before, I think now is a good time to start looking into objects/functions/classes - are these good tools to use? If so how would I go about using them?
Cheers,
Freakish_05
You might want to look into creating an MVC framework.
Functions and classes are excellent tools given the right application, definitely worth using in context. Take things by semantics: repetitive code sections? Make a function. Collection of functions working towards a common goal and sharing variables? Make a class.
It all depends on the scenario and scale of the project.
