Guys,
I need some help. Due to a need to re-arrange I have to build a new PC to be my home server. The 'server' will sit in the corner of my dining room under a table so there is a need to it to be a quiet as possible (the sound of a 747 in the corner does not make for a pleasant dining experience!)
It also needs to be able to keep all the kit inside it cool, fortunately most of it is not new hardware so shouldn't run too hot.
In the system will be:
So with all that in mind, any ideas as to what case would be a good idea? Two I looked at are the Antec 900 and the Coolermaster Cosmos. Never seen either in the flesh though so I don't know what they are like.
- Pentium D 820 with a quiet / silent HSF (advice on the HSF also welcome)
- Motherboard of some sort - not sure which one yet as I need to purchase (new or used). Preferably an nforce board with built in gfx.
- If I can't get above with a built in gfx card then I will stick in something old like a silent geforce4 mx 440
- 2 x Nova-T DVB cards
- 1 x Sata Raid Card
- 2 x 160Gb Sata Hdd
- 4 x 500Gb Sata Hdd
- 1 x IDE DVDRW
