Hi,
Has anyone got 2 x 5870s in crossfire on a gigabyte ex58 ud5 board as i am thinking of banging another one in there but it looks kind of tight betwwen the pcie slots and if possible any advice on what to watch out for if anything..
Thanks![]()
Is there not 3 X Pci-e X 16 on that board and if correct could you not put one card in 1st slot and second card in 3rd slot keeping them well apart, or is that not possible.![]()
Hi mate thanks for your reply and yes there is another but its only x8 do you know if this makes much of a difference....
Negligible.
have same board and Xfired 5870's.
The only thing that may cause a prob is clearance over the usb and case headers if you move one down to the x8 slot as far as I can see!
Hi mate
Thanks for the information.. and thanks to all whos posted so far..
One of the reasons i want to put another card in is because my brother has a 8800 gts card and he gets 7.5 on the windows experience and hes taking the **ss out of me as my windows experience for graphics is only showing a 6..
We are both running windows 7 x64
Did you put the second graphics card in the other 16x slot and if so i assume it fits ok..Is it worth doing.
The other thing is whats the temps like...
You can hack the system to give you a bigger number. That should save you money!
The windows experience score means very little, real world benchmarks are a more reliable rating system.
Backup a sec, only 6? I'm getting 7.4.
