- 3 Nov 2010
whats the current faves out there - is there anything better than the denon x2800H for £600
Both the Denon and the Sony should be prime candidates if you're looking to buy an AVR for under £1000. We can't deny that we prefer the sound of the Sony, but if you're on a budget then the Denon simply makes sense considering it too is an Award-winning AVR.
My Denon X2400H is 6 years old and it started acting weird (powering off randomly) and then just not turning on at all. Thought that was it, game over. Turns out it was just the fuse in the plug.If you can scrape £100 more, the Sony TA-AN1000 is often on offer, I imported one from Amazon.fr for £630 2 weeks ago, and it was £699 in the prime day sales for 2 days and this was being matched by many retailers.. its just gone back up, but Black Friday would surely see it discounted again.
Coming from a Denon X2500h, the main upgrades are really down to the Sony's 360 Spatial Sound Mapping feature.. it absolutely does an amazing job on recreating extra speakers and giving an unrivalled bubble of pin point 360 sound. The bonus on this is the centre channel can be compensated to really appear as if its coming directly from the screen at the right height and was a huge improvement for dialog.
Also, previously I had to compromise by choosing a 7.1 or 5.2 layout for my 7 speakers, since the majority of my source material was not in Atmos, I preferred the 7.1 setup, but for Atmos movies, the 5.2 setup sounded better.. but you can't keep moving your speakers around. I was contemplating going for a 7.4 setup which needed a much higher spec amp and 4 more speakers, but the Sony allows me to have a 5.2 setup (2 mid height speakers in my case) and the 360SSM fills in the lower mid-surrounds perfectly so I can now enjoy the best of both worlds with just 7 speakers. I think you only need 5 speakers to get most of the effect for a full 11 speaker setup (4 height, 7 lower).
Music also sounds oddly good with the 360SSM allowing this enveloping sound stage to which many people actually prefer leaving that on, but I guess will be down to individual taste..
Other than that they are much of a muchness:
Sony's Product of the Year-winning home cinema amp is back down to just £699
Here's why you should buy it.www.whathifi.com
The X2500h just stopped outputting any audio randomly.. this is the second Denon AVR that struggled to make it beyond 5 years, the Yamaha and Sony's I've had prior to this didn't miss a beat, although I still love my old Denon AVR3802 which is much better build.
My Denon X2400H is 6 years old and it started acting weird (powering off randomly) and then just not turning on at all. Thought that was it, game over. Turns out it was just the fuse in the plug.![]()
That is what was happening. Tested the old fuse, dead. It has been about a month now and all fine.A fuse would either work or won't.
That is what was happening. Tested the old fuse, dead. It has been about a month now and all fine.![]()
Cheers, yeah understood. Will keep an eye on it. Your idea sounds plausible. TaThe random switching off is a concern. Either it's blowing a fuse all the time, or it's faulty PSU/dying but not blowing the fuse (then finally it did) Or if it is blowing fuse after fuse, then it's got a failure inside and the fuse is doing it's job
Sounds like it's on its way out tbh.
