Advice on device needed
29 Aug 2011
Hi,
I've had a look on the FAQs and google but I'm still confused. Basically, my current setup is an Ethernet cable running from my virgin router into my bedroom where my pc and ps3 are. At the moment I'm taking the Ethernet cable in and out of each device as required but I'm hoping there is an easier solution.
I think I need the current Ethernet to run into a switch then have 2 cables running out of the switch into the ps3 and pc?
Any help is appreciated!
Cheers
