I have a little project that I need some help with. I basically have an HTML page with a table in that displays data from an xml file. Now this displays fine but I need the page to refresh every 1 minute, and display new data from a new xml file. I can do the auto refresh bit, but obviously the file name of the xml file will change.
The xml filename will take the format of 15102006_1326.xml then the next will be 15102006_1327 e.t.c (so a timestamp in effect)
So what I need to do is have the html file change its source to look at the next xml file every 1 minute
Any ideas or tips?
TIA
Any ideas or tips?
TIA
