Advice on Drivers
8 Oct 2008
Hull
I have put an old x1950 into a mates system, he has windows 7, we have installed catalist 10.2 but the ccc control panel wont load, my question is whats the best driver version and ccc to install for this aging card and win 7?
Any advice much appreciated!
I don't know which one you should try and use for the best but there are no official Windows 7 drivers for that card.
AMD say you can try the 10.2 Vista driver but give this warning:
Note: AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration.
