Hi,
Shortly I will be ordering the components for my new dual loop 900D build.
The setup will be as follows;
3x Titan X on one loops
CPU, RAM and MB on second loop.
I am looking at the EKWB Coolstream XE rads and was planning on mounting a 480 in the base and a 480 at the top. I am not sure what kind of radiator capacity my setup will require. I am happy to add a third or even fourth radiator (two per loop). I intend on removing all the HDD cages and the 5.25" bays as I will mount my SSD somewhere hidden and I will have an M2 drive. I don't intend on having any HDD or Blu Ray drive (I will have an external for the very rare times I need to use it).
So I guess my question is;
Will 3x Titan X require more than the 480 rad and if so would a single or a double be required?
For the CPU, RAM and motherboard will the 480 be enough or again will I need more RAD capacity?
Also I am intending on not having an exhaust or inlet fan as everything will be under water, is there any reason that I should not do this?
