Advice on first SFF build
30 Sep 2008
Chelmsford
I have bought Tutes V350, and im thinking of putting together a cheapish build.
Now what i cant decide is whether to go intel or AMD!
Components so far:
V350
5750 or a 4890 watercooled (will have to check the case!!)
600W PSU
at the moment i have (supposed to be building a cheapy for a customer) a G31M-ES2l and a E5300, now should i use these or buy AMD and "save myself a few quid"
Also what would people recommend as the best cooler i could get in here!! or should i get myself a double RAD and W/C the GPU and CPU as i already have a pump, res and dual RAD!
You bought Tutes V350... nice. Well in that case you pretty much have to got watercooled :D
Mini Ninja fits nicely though.
Now if you are building this for the customer then through the cheapest in, if not then get the best parts possible and have yourself a box you are going to be proud of.
They are very nice, don't let it go to waste.
Just shopping about for a RAD, will it have to be slim or can i put a TFC/Thermochill in there!!
