Advice on graphics card
26 Dec 2005
Liverpool
Will a graphics card that is a AGP8x run okay on a motherboard that has a AGP4x slot.
Thanks folks
Should run fine, and you should'nt notice any difference really. :)
Id wait for some more confirmation just to be on the safe side, but im sure it would be fine as said.
It will be fine, the voltages are the same and there isn't that much of a performance loss to be noticeable. Well at least not enough of a loss to stand out against the fact that anything with an AGP 4x slot is likely to be pretty slow anyway :)
