I am having all kinds of problems on Hamachi recently and I've no idea why! HELP!
Basically I dont know what settings to use as I am having problems pinging the other people in the network, it either pings a few times and then times out or the ping gradually gets higher and higher (upwards of 1700ms sometimes!)
I once seemed to have some success by putting a port number in the UDP & TCP boxes within the Hamachi setup and then putting it in my routers port forwarding section - is this right??
Basically I'm after a tutorial to get the best possible connection via Hamachi!!
Any help will be appreciated....
StevieP
StevieP
