Hi guys, I'm a total newbie at this but I've had a look online at a couple of resources for information, and I've come up with the specifications for a build I'd like to try, but before I buy anything I could do with some tips. My overall budget is £300-£400 and this build is looking like it fits nicely in that category. One of my concerns at the moment is that I'm not sure if I'll need additional power supply or cooling. Secondly, I'm not sure if the hardware I'm looking at is necessarily compatible or likely to work better than other options in the same price range. If somebody could give it a quick look over and give me some tips, I'd be really grateful. Thanks in advance, here's the specs:
PC Case
Coolermaster RC-600 Gladiator Case - Black [RC-600]
£52
Hard Drive
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM 1yr Warranty (ST31000518AS) [ST31000518AS]
£38
CD-ROM Drive
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM [SH-S223C/BEBE]
£14
Processor
Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz (1066FSB) - Retail [BX80571E6500]
£62
Motherboard
Gigabyte GA-EP45T-UD3LR Intel P45 (Socket 775) PCI-Express DDR3 Motherboard [GA-EP45T-UD3LR]
£85
Memory Modules
Corsair Value 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low Voltage Dual-Channel Kit
£44
Power Supply
Don't know if I'm going to need one or if the case has one or what...
Video Card
OcUK GeForce GT 440 1024MB GDDR3 PCI-Express Graphics Card [SXT4401024S3NM] (I know this isn't yet available but I can probably wait till it is).
£60
Total cost: ~£355
Any tips would be really thankfully received.
PC Case
£52
Hard Drive
£38
CD-ROM Drive
£14
Processor
£62
Motherboard
£85
Memory Modules
£44
Power Supply
Video Card
£60
Total cost: ~£355
