- 18 Feb 2009
- Burton Upon Trent
Hey Guys below are pictures of my current setup - TJ07 watercooled with a triple radiator and a combined pump/reservoir. I have decided to renovate my computer, I need to change the water in it, so i'm going to go for a black/white theme, white braided cables and white tubing. Looking at my computer is the pump/reservoir in the right place? Is there anything I could do to improve the setup while i'm refurbishing it? This was my first attempt at watercooling btw.
Another question is should my fans pull air through the radiator or push air through it? Finally I have a GTX 295 and about a year and a half ago I bought the water block to go with it. I got all the screws out apart from one and you can see I knackered the head of it. Now I would really like to include the GPU in my circuit, anyone got any ideas of how to get that screw out? (then maybe put a different one back in lol?)
Anyway here are the pictures:
Yes I know I need to work on my cable management skills
Thanks Guys
