- 5 Feb 2007
Hey there.
I asked this last week and decided to wait a while and think about it before ordering.
Can you tell me if this is a good choice of components for my new pc?
Here is the spec
Antec Nine Hundred Ultimate Gaming case
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail
GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit
BFG GeForce 8800 GTS OC 320MB GDDR3
Samsung SpinPoint T HD400LJ 400GB SATA-II 8MB Cache - OEM
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler
Samsung SH-W183 18x18 DVD±RW Serial ATA Dual Layer ReWriter
Does that look good?
Will the power supply be enough?
I want to try and overclock the E5400 to about 3.GHz but after reading in the overclocking section i see that memory seems to be a big factor in overclocking the CPU, and also the motherboard
Will that memory be ok with that motherboard and the E6400? I am new to overclocking so i would not really want to fiddle with the memory any more than a small easy tweak.
Also would i need to update my motherboards BIOS ?
(i dont even know what that means let alone what it does or how to do it
Apart from that, will all the things there have all the cables and wires needed to assemble them properly?
Oh, and does the Synth Ninja come with its own thermal paste?
Here is the spec
)Apart from that, will all the things there have all the cables and wires needed to assemble them properly?
