Advice on new 24 inch dell/my system
26 Apr 2006
Hi all,
just need to know if my system is good enough to run 1900x1200 resolution on most games with aa turned off all the time(becuase at that res i can do without it).
would a dual core upgrade be adviseable?? if so which one??
check my sig for my system(7900gtx is oc'd to extreme speeds)
thanks guys.
im pretty sure you'll be fine with that card. id even say that you could but aa on x2. just mess about with the shadows and textures and you should get it looking nice and running smooth
not really. i sold my 4400+ @ 2.7ghz for my single core opteron which runs @ 3ghz. feels a lot smoother in games and loads considerably quicker
if you really want to blow some money spend the money you've got for a dual core proc and buy an ocuk 7900gtx for sli
EDIT: just noticed you got shuttle oops, maybe not sli
